purchasing a printer from ebay need some advice pls Sp300i
Re: purchasing a printer from ebay need some advice pls Sp300i
and Pennz if you are not a premium member just get the membership that will save you money straight away 10% discounts from some good suppliers ..
Hi Scotty you are a star ..Thanks you so much ..I tried on the net but had no luck ..THANK YOU SO MUCH AND ALSO the info about the head ..He send me some pictures and a video it was printing the test print and it seems perfect ..But Ill check it my self ..Guy seems to have a business running events all over Europe and sounds genuine (Price is not tho lol ) ..I can see it tomorrow ..So I am going to install the RIP to my laptop now .Again Scotty thank you so much .....
Best of luck, hope this works out for you
Thanks Justin I have something to ask from you personally ..I will send you a PM now
If it is fine just remember that you need to lock the heads, drain the ink, empty the waste tank and some other bits and pieces when transporting. I only know this from seeing it on other forums. I don't have an actual link but I am sure Google will be your friend here.
You have no protection at all with paypal on collection items.
Thanks for your kind support guys ..Quisfan and Viccar thanks for your advice too ...I bought the printer ..Its working as the described and the guy seems really nice and genuine ..But don't know what to come later lol... .Now I need to buy ink and some materiel to do some test prints and stuff like that and I am sure I'll have lot to learn .....Ill update with the results asap ...Thanks again
HI guys managed to get a test print today ..Not so sure this is good or bad ..I can see some banding on Cyan (May be due to few blocked nozzles )and print quality is not solid as my normal printers .Is this test print look okay ??... Thanks
How long has it been sitting with no ink? Run a power clean to see if it clears the banding.... do a test print via the panel and drop a picture here
That test print wont show much ... this is mine when I bought the VP...look ok yea!
But you can see here, at least one head is shot
Scotty thanks for the update... I had no ink on it when bought it as the guy took them off ..orderd new ones and took a day to receive and I only done a simple clean and the tear print ...I'll do a power clean and update ..thanks again for the WS link u gave me..I had no clue otherwise..
