Sublicotton
A11kns
Re: Sublicotton
Post by A11kns »
Tried this again... Installed the ICC profile but still getting this result before I put the power on
Re: Sublicotton
press it ;)
and then show some photo.
Mugshots
Re: Sublicotton
Post by Mugshots »
What printer are you using?
Mugshots
Re: Sublicotton
Post by Mugshots »
Is it Ricoh?
logobear
Re: Sublicotton
Post by logobear »
my guess is loose lint on the fabric?
Have you tried a lint roller first, - or the backing from vinyl, - to remove any loose bits of fluff so it cannot stray?
A11kns
Re: Sublicotton
Post by A11kns »
I'm using a Ricoh 3110
I've used all my paper now. But it looked the same as what I had already pressed, hence why I didn't press that image.
Tony4415
Re: Sublicotton
Post by Tony4415 »
Hi
I use this stuff, must print at high speed and make sure the powder is clean.
