Sawgrass SG400 - how long can it be left without printing?
Mike-E
Re: Sawgrass SG400 - how long can it be left without printing?
Post by Mike-E »
Will be away for a couple of weeks and wondering how long the SG400 printer can be left before the print heads become clogged?
wayupnorth
Post by wayupnorth »
Just leave it switched on, not used mine for several months and printed a head check the other day, perfect.
Mike-E
Post by Mike-E »
wayupnorth;112593 wrote:Just leave it switched on, not used mine for several months and printed a head check the other day, perfect.
Thanks, will do that. I did read a post, somewhere on DSF, saying that leaving the power on uses much or all of the ink over time. Possibly will make a note of the ink levels before leaving then once back in.
wayupnorth
Not noticed any significant level drop but I believe there was a scenario with its predecessor where a power failure caused a deep clean when switched on again. Used my 3110 in the highlands during frequent power cuts but never had a problem.
JMugs
Has thanked: 9 times
Post by JMugs »
I leave my 3110 on, very rarely use it as it's only a back up. I do a check print every few months and it's fine. Uses very little ink.
Janners
wayupnorth;112596 wrote:Not noticed any significant level drop but I believe there was a scenario with its predecessor where a power failure caused a deep clean when switched on again. Used my 3110 in the highlands during frequent power cuts but never had a problem.
Had this happen twice now, power went off when I was away from the office, inks emptied into waste, waste filled :-(
Mike-E
Post by Mike-E »
Justin;112602 wrote:Had this happen twice now, power went off when I was away from the office, inks emptied into waste, waste filled :-(
Could be a bit expensive!
