just showing off :)
Re: just showing off :)
Nice Paul....regarding the transfer sheet you use how many times can you 're-use' it? The Siser is supposed to be good for 6 cycles although I usually only use it a maximum of 4 times.
I use TTD Easy and have reused that over 20 times on some media when doing tees or hoodies so works out quite cost effective.
i use it only once
no way i am going to store them and than unstick them. so only one use and then in the bin.
mags1892
Paul;111598 wrote:Hi Lianne,
Yes. Stuff I use now cost £1.03 +vat. grafityp cost £1.65 +vat per meter (based on 25m log)
I use it ONLY because the price. Transfer tape has no effect on quality of print and its discarded after use. So I cant see any point of paying more. Tbh, I recon even £1.03 its to much for what it is.
Cant find it on there the link is £1.30 per metre is that the saem stuff, shows £1.02 or something till you pick clear which is the only option lol. Im looking for this right now for working with yolo opaque papers
Put it to the cart as a 25m log it will show up properly
Arfermo means if you've a run of garments to do the ttd stuff is reusable on the next then the next, would the stuff you got be capable of multiple reise or do you mean it's a one hit wonder that looses tack after one use as that would make it less cost effective in comparison
does the printed output from the BN-20 need time to dry before pressing?
Logobear... No, it's pretty much the same as a versacamm but slower. Print, cut weed and press pretty much straight away.
Depends on the media Logobear, some are usable straight away and some are not although I'm always a bit cautious with freshly printed stuff unless in a rush. Okay yes that happens and as we speak I've an order for a large group going out to Ibiza tomorrow, shirts arrived late this morning so next job is printing them then pressing soon after for collection later.
Mark
Mark
