Xpress A3 + sub paper , True Pix A3 and Jet Stream paper ..
Ravisteam
Re: Xpress A3 + sub paper , True Pix A3 and Jet Stream paper ..
Post by Ravisteam »
Hi guys I am using A3 Jet Stream paper for printing Cushion covers...With Jet Stream paper tho I get a slight ink transfer to the other side of the paper after its pressed so the problem I am getting is If I use a silicon paper (to cover the paten ) when pressing ink will be transferred to the silicon paper too ..So it cannot be used again..I never used Xpress or True Pix paper but I hear good things about them . ..Do you get this issue other those papers too ??....Thanks in advance ..
I had the same problem. Never have the issue with Trupux, Xpres paper is very good but doesn't transfer as well.
Ravisteam
Post by Ravisteam »
Justin;111836 wrote:I had the same problem. Never have the issue with Trupux, Xpres paper is very good but doesn't transfer as well.
thanks Justin
