new to here today
- sinotransfer
Re: new to here today
at last , successfully login. thank you.
hello everyone, my name is Yeste. comes from China.
i do the heat transfer/press,also silkscreen.
come here to learn and communicate with u all.
heat transfer machine, heat transfer paper
www.sinotransfer.com
- sinotransfer
thank you, Justin
good luck , all of us
welcome on forum friend!
- sinotransfer
bms wrote:Welcome to the forum. Are you an end user or a supplier?
i am a supplier
Hi Yetse,
Just had a quick look on the website that you have linked on your details - some of the images on the front page have been copied from a major supplier in the UK and I would assume this does not have their permission. I'd recommend you let whoever deals with your website that these need to be removed.
- sinotransfer
bms wrote:Hi Yetse,
thanks for your advice.
i will check and then solve it well
