Changed my paper so do i have to change press times?
Re: Changed my paper so do i have to change press times?
I Have changed to pree cut Beaver TexPrint R Mug sized paper.... do you have to change heat and time settings?
You should probably be OK at your original times, just watch out on the flesh tones.
You'll more likely need to get a new ICC made for the new paper.
