fonts disizeing
Re: fonts disizeing
I use photo shop and for some reason my fonts are all over the place. when I use them now the come up too small and when I use the return the gap is huge. I have changed something but have'nt got a clue how to put it right. Any suggestion, I just have brought a load of images from someone that uses apple, but its just not on his images but also on mine.
Re: fonts disizeing
You could try this, should work for CS2 and CS3 and maybe others.jennywren wrote:Anybody any ideas. my fonts won't play ball
I have not tried it, but it is meant to set photoshop to default initial settings.
How to reset Photoshop preferences (In Windows):
First, hold down all three Ctrl+Alt+Shift buttons
Now "while keeping those button held," simply open Photoshop or a file that opens with Photoshop
As Photoshop loads, you should get a prompt asking if you would like to "delete the Photoshop settings file", Click yes
You should now have a fresh slate with all of the settings returned to their default.
Note: This process is kind of finicky and doesn't always work. I have had the best results pressing Ctrl+Alt+Shift and clicking the photoshop shortcut from the start menu in Windows.
Dave M
Re: fonts disizeing
I was up till 1.30 trying to figure it out, I'l have a go when I get in from work. Thanks for that.
Re: fonts disizeing
No problem, let us know if it worksjennywren wrote:I was up till 1.30 trying to figure it out, I'l have a go when I get in from work. Thanks for that.
Re: fonts disizeing
Font size - Have you altered the size in the toolbar along the top when the text tool is selected?
Gap between text lines - this can be altered in the character options box, which can be accessed by clicking on the icon that looks like a page, generally on the right of the same toolbar.
