FOISON C24 USB Cutter
Kaz
Re: FOISON C24 USB Cutter
Post by Kaz »
I bought a Liyu cutter from a guy on ebay, which I believe is a clone of the graphtec cutters.
After a lot of faffing about (over 3 months), it turned out I had a faulty cutter. The guy replaced it no problem, and I must say, it's brill :D
It's a 54 inch cutter, and cost me, including delivery, about £260.
It will cut precisely at as little as 3mm circles (rhinestones) it even cuts the heavy duty stencil film without thinking about it.
It has a pressure range of 1-400g, and is really quick and easy to use.
So, cheap is best isn't always the case, but in this instance, it's worked for me :D
R.Prints
Post by R.Prints »
I bought a secondhand Foison, then ended up buying a second as it was a good price and I thought it was a good idea. Have had them for about a year and still can't get it working. Have tried everything I can find about setup etc but still no luck. When you look for info about them it seems there is a lot of problems getting them to work.
John G
Post by John G »
Why after buying the first plotter, and could'nt get that working, why would you buy a second. Doesn't matter where you bought it from you still have rights - if its not right, send it back.
