wifi
Re: wifi
There any way to connect my two wf3010s via wifi? Ive got the one done and just run the other via usb cable at the mo
wayupnorth
Re: wifi
I am using two powerline adaptors (maplin) to create my network (hardwired via a switch) in one room which includes the BT router (hardwired via network cable) in another. Works at full speed (17Mbs) with the occasional dropout. 5 port netgear switch not expensive and you can connect both printers via network. You can then use wifi via the router or network via your pc so the best of both worlds.
