Cut lines on mugs?
LDI Graphics
Re: Cut lines on mugs?
Newbie here so this question may well be simple enough for you guys. I produce bundles of contour cut graphics for clothing, stickers and vinyl graphics for all sorts of applications. In my head I'm thinking if I produced a design via dye sub for let's say a mug but the design didn't cover all of the mug would the blank part (white bits) just be invisible on the finished article? I use eco solvent inks in a wide format print & cut machine so I can't use my current equipment for this process.
White blank bits won't be printed and you'll only see the white of the ceramic. There is no advantage for the graphic to be contour cut.
LDI Graphics
