Help! New printer (Virtuoso SG400EU) Printing very dark!
edwardsmedia
Re: Help! New printer (Virtuoso SG400EU) Printing very dark!
Post by edwardsmedia »
I've only had this printer recently from Listawood, the Virtuoso SG400EU and not use it much at all, but the prints seem to be real dark! any idea why?
I have attached the original JPEG oh what they should look like, then 2 of each of the same coaster, but the top line of coasters has the correct settings they recommend in the guide. and the other just normal print settings (as you would print out any piece of paper on any other printer)
Very confused :(
Coasters are from Xpres (9cm x 9cm hardboard, used these for years) paper is from xpres (A4) and the inks are the ones which came with the printer from Listawood ( Sawgrass)
vB_ID:3732
vB_ID:3732
order #1048970619 PROOF.jpg (12.86 KiB) Viewed 258 times
vB_ID:3731
vB_ID:3731
vB_ID:3730
vB_ID:3730
Isaac11
Post by Isaac11 »
Did you use the right ICC Profil ? or did you use Powerdrive ?
edwardsmedia
I used powerdrive~V4 SG400 (EU) ...Should i have used Sawgrass SG400 RPCS-R maybe?
edwardsmedia
I am using Corel Draw X5 just so everyone is aware (I believe i followed the instructions when installing very well when installing and can't see anything different than what i read in the sawgrass manual) Must be my settings on the computer?
Quinsfan
Post by Quinsfan »
How long did you press for and what temp. Have you tried a lower time. I have sometimes put the photo into Gimp and just lighten them up a bit before printing them off.
edwardsmedia
200 for 50 secs (i have always press at that time with these coasters)... nope not tried a lower time on these... :)
