Good cutter to start off
malfunction
Re: Good cutter to start off
With you being new to this I would recommend seeing it working, The 5000-40 is a great machine, I have both that and a roland cx-24.
Is there a model number on the Camm 1? If it's a cm-24 or a cx-24 it's a bit overpriced, if it's a gx-24 it sounds a bargain if it's working ok and not been abused.
I would defiantly stick with a "proper" cutter like a Roland or Graphtec, the Chinese ones can be a pain to set up and most are not too reliable.
Roland camm 1 vinyl cutter with laptop and vinyl.
Here is a great starter pack for your own decal business.
Make wall decals, tshirts, bags. Plus many more items
Thats the advert for the roland, its only 30 mins away so I could go and have a look at it.
Im planning on doing sub printing for tshirts, phone cases and doing vinyl stickers for cars or tshirts.
Ive got a macbrook pro that I was planning on using but not sure on what software, would it be worth me getting the roland set up as it comes with a laptop.
Im planning on buying either the roland or Graphtec cutter.
This Epson printer for £240
http://www.ebay.co.uk/itm/Epson-Photo-1 ... 58cec6faf1
Was thinking about the Galaxy Neptune Heat press. just not sure what size to get yet.
Then probably get the neptune mug press too...
If you can advise about the set up let me know.
malfunction
Ok, it sounds like the roland is an older model, though still a good machine it wont have usb which causes problems with newer computers not having serial or parallel ports, also newer operating systems can be a problem. Even though it's local I would pass on it.
Regarding the printer, unless you really need A3 the Ricoh/Sawgrass A4 is much more suitable for sublimation and is a similar price including proper sawgrass ink. Having said that I use an epson and it works ok though not without problems. I will buy Ricoh when funds allow.
Good news is the Neptune gets really good reviews, one here from Paul (one of the mods on here) https://www.youtube.com/watch?v=38XlexyJG6w
Best advice I can give is to have a good look through this forum and youtube you will get so much info on setting up. So many people just dive in and buy on impulse and regret it later.
Would you pass on the graphtec one then or just try to get it cheaper??
The printer I researched on here, thats why Ive gone for it.
Glad about the neptune... would you recommend a decent mug press? would like to do latte classes and different size cups.
Could I use the graphtec with my mac via usb?
malfunction
I think the Graphtec would be ok for you, it will work on your mac via usb, The supplied software is more than adequate. I think it is overpriced at £350 though, The new model 6000-40 is about £670. It's a shame your so far away, i'd be happy to show you mine working.
Regarding a mug press, i'm no expert on them, I have a cheapy one that works ok for the few mugs I do, I suppose it's down to your budget, You will need maybe the 16 x 20 heatpress if your going A3 printer that's the best part of £500 + £240 for the printer and say £300 for a cutter, that's without ink and other consumables.
[h=1]Graphtec CE5000-40-CRP ( Craft Robo ProS ) Vinyl Cutter.[/h]Graphtec CE5000-40 vinyl cutter in excellent working condition. Usual marks with usage. Comes complete with mains & usb cable, driver & software disc, rear vinyl rollers, 2 used sticky mats for contour cutting ( these can be revitalised using spray adhesive ), 4 discs with various templates and printed user instructions. This is far superior than the Silhouette model. I am still using this so I can give a demo before parting with any cash. £350.
ill try to knock him down... If not Ill keep my eyes out over the next few months and see if anyone from here is upgrading or anything.
malfunction
I wouldn't pass on this untill you know what model it is, the camm 1 is the series, it could well be a gx-24 and they have not added the "pro or servo" bitLavinl30;105066 wrote:Roland camm 1 vinyl cutter with laptop
(with it running via a laptop it's possible it's USB
Well worth asking the question or asking for a picture just incase you're missing out on a good cutter
I had a Epson A3 which worked ok, but when I got a Ricoh there is a big difference between the 2! as said if you dont need the A3 printer, go with the Ricoh...
- logos unlimited
Hi Kath,KathG;105052 wrote:Hi Paul,
No problem. I purchased from The Magic Touch. It was £595 + Vat
Its a great cutter, just finished cutting 3 different HTV's and it did not miss a beat. Love it. Though now I'm wishing I had bought the 24". We are never happy....LOL..
Thats a good price, do you get your vinyl from Magic Touch or Expres ?
Regards Paul
