Lines or banding
Jimmypepper
Re: Lines or banding
Hi I'm using a Ricoh sg3100 to do my printing the software I use is photoshop on a windows 8.1 pc but when I print I get evenly spaced banding on phone cases and mugs ,I think I need an icc profile but don't know where to get one can anyone help .
i have seen on here that there is someone who will do one for me but can't find him so again any help would be welcome
You need to talk with Paul on here mate (Paul is his username
If you are using a Ricoh I assume you are using Sawgrass inks as well and the Powerdriver so an ICC is not really required. Is the banding on the paper before you print? What paper are you using?
sounds more like a head alignment issue or blocked head. so head clean should help.
regards
regards
arthur.daley
I have had issues with banding from my 3110 print out has a fine white line through it across the page and at regular intervals - looks like a blocked head but with the regularity of a transport problem. It is most likely to appear when I have been given a .png file to work on. I have found that sometimes if I go back to the original .png and save it as a tiff I can then reopen it and the problem goes away. On other images I have had to ask the client to supply a tiff or jpeg.
I spent forever trying to figure out what was going on I did the full range of head cleans and printed the test pattern out dozens of times I must have wasted gallons of ink trying to head clean the problem away before I noticed the .png connection .
Hope this may help
Arthur
Hope this may help
Arthur
Jimmypepper
Thanks for that Scotty I have had a word with Paul and hopefully that's sorted everything out
Jimmypepper
Thanks for that yes you are correct about the ink but as far as I can see there is no powerdriver on saw grasses site so not using powerdriver unless I can use the 3110 but I don't know.
again thanks
again thanks
Jimmypepper
Hi Paul thanks for the help it looked like realigning the heads helped and we flushed them just to make sure now it seems a lot better but time will tell again thanks
Jimmypepper
Thanks Arthur yes it might help any information is useful and welcome so thank you
jim
jim
No worries mateJimmypepper;104334 wrote:Thanks for that Scotty I have had a word with Paul and hopefully that's sorted everything out
Have a look here http://www.sawgrassink.com/login?Return ... izard.aspxJimmypepper;104335 wrote:Thanks for that yes you are correct about the ink but as far as I can see there is no powerdriver on saw grasses site so not using powerdriver unless I can use the 3110 but I don't know.
again thanks
You need to sign up to get the download but it may help a little more
