CE6000-4- print & cut
kermit
Re: CE6000-4- print & cut
Post by kermit »
Hi, I'm looking for a guide on print & cut using Graphtec CE6000-40 and cutting master 3 plugin with Corel Draw X7 (just bought the cutter).
Keith
Quinsfan
Post by Quinsfan »
Do you mean that you are printing on one machine and then wishing to use registration marks to cut your print using the cutter? Does the cutter do contour cutting?
kermit
Post by kermit »
Quinsfan;104156 wrote:Do you mean that you are printing on one machine and then wishing to use registration marks to cut your print using the cutter? Does the cutter do contour cutting?
Yes to both Quinsfan.
