Please help, red marks on final product
Re: Please help, red marks on final product
Im using the 3d mini sublimation machine. and an epson l120
When I print it it comes out fine, no red or magenta marks, then after i finish sublimating it this is the result, it always happen when I have black color or dark colors, some magenta comes out of the sides. here is the pic, can pls anybody help me, thankyou in advance.
I dont have any ICC profile since I only use china inks coz thats the only inks availble here. I already tried finding someone that can make me a custom icc profile here in our country, but no luck, i cant find any. =(
already wasted like 15pcs blanks on trial and error, and im still getting this
We can make them for you on here see this thread http://www.dyesubforum.co.uk/vbforum/sh ... le-service cost is GBP 25 I believe.
omarperalta
Hi serec, i'm using china ink too i think its the ICC too. it may be that your printer its putting too much dark ink, you can try play with the CMYK values, that's how we are doing it.
Hi Omar, are you using an ICC on your china ink? Can you tell me what do u mean on playing the cmyk values, you mean on the printer settings or the actual design? Can you tell me how you do it for example
omarperalta
The RIP software the we use came with the ICC. And I play with the percentage of INK that it shoot. And when I say CMYK it the software that you use for the art ex: illustrator or Photoshop. If you are working with images you need to make the colors lest darker. And if you are working with vectors play with the values of the colors. If you need help with color matching just send a message.
I tried doing what you said on ur website about the raster image tutorial, it came out good after I print it, then when i finished sublimating it its still the same problem, it becomes magenta. =/
Im wasting too much blank case and ink. I cant seem to get it, pls someone help me. Its really okay when I print it the problem is after sublimation.
here is the image
here is the image
- vB_ID:3685
- 11908028_1047604781916975_336458858_n.jpg (49.74 KiB) Viewed 339 times
- vB_ID:3684
- 11931683_1047601185250668_1079236872_n.jpg (64.34 KiB) Viewed 339 times
omarperalta
Please send a picture of the original image on the computer to see the difference
Sent from my Nexus 4 using Tapatalk
