Hi, I bought a second hand cutter, I believe it is a US cutter machine. Got it working under Windows 7, laptop went bang and had to get a new one which has Windows 8.1 , I just cannot get the machine to install. Computer sees it as a USB device. Any ideas suggestions.
Thanks Cyprian
Sent from my HTC One_M8 using Tapatalk
MH 1351 cutter
cyprian.costelloe
- rickycalla
Re: MH 1351 cutter
I would have a look for the newer driver for the cutter. Is it a 32 or 64 bit driver/computer?
I'd imagine if you contacted the manufactured you wouldn't need to say you bought it second hand. Just you bought a new computer and now it doesn't work.
Good luck!
Good luck!
cyprian.costelloe
Re: MH 1351 cutter
Got it sorted thanks, the manufacturer has a forum and there was an newbie walkthrough on setting up the cutter.
