Advice needed
jennywren
Re: Advice needed
Post by jennywren »
I am looking to buy a heat press to do polo shirts and t.shirts, not looking for a cheap one. Can anyone recommend one. I have looked at magic touch and they do give good support. But no idea about how good their heat presses are. Can anyone help me through this minefeild
Dave271069
Re: Advice needed
Post by Dave271069 »
The Magic Touch, would be my first and last point port of calll, Great Heat Press's Great service,
ASO Embroidery
Re: Advice needed
Post by ASO Embroidery »
I have a pressmech very good press but the atkins presses are very good to
Sammy
Re: Advice needed
Adkins and Pressmech are both superb but the latter has the edge for me, I have the deeper bag press with a polo platen.
JMugs
Has thanked: 9 times
Re: Advice needed
Post by JMugs »
Pressmech...still made in England and bomb proof.
jennywren
Re: Advice needed
Post by jennywren »
Thanks everybody for your imput, I went with Magic touch, yes they are bit more expensive, but every time I have phone they have been very helpful. Even though I've not brought anything of them for a while. I have one of their OKI printers that uses wow so that where I went.
jennywren
Re: Advice needed
Post by jennywren »
I have use the press from magic touch today, and jet stream paper this is the first time I have used either of these. Apart from the press being on the floor at the moment as I'm awaiting a trolley, I will say I am very impressed on how these both of these items work. The image was great and clear with right colours, the press was easy to set up for time and temp and easy to gauge the pressure. I highly recommend these two items. Hope this helps if you are deciding to buy a press or looking for a decent paper to use. I have only ever used trupix and have found that excellent as welll
JetStreamDigital
Re: Advice needed
Post by JetStreamDigital »
jennywren;102683 wrote:I have use the press from magic touch today, and jet stream paper this is the first time I have used either of these. Apart from the press being on the floor at the moment as I'm awaiting a trolley, I will say I am very impressed on how these both of these items work. The image was great and clear with right colours, the press was easy to set up for time and temp and easy to gauge the pressure. I highly recommend these two items. Hope this helps if you are deciding to buy a press or looking for a decent paper to use. I have only ever used trupix and have found that excellent as welll
Hi jennywren,
Thanks for this. We are gradually rolling out to more distributors, so I'll keep you all posted on the forums, along with further product releases!
BR,
Jimmy
Sent from my SM-G925F using Tapatalk
logos unlimited
Re: Advice needed
Post by logos unlimited »
Hi Jennywren,
Try
wicked print there down south and the main man is pete if you ask for him and be cheeky he will knock some thing off.
