Wallets?
Scary
Re: Wallets?
Post by Scary »
Hi
I've bought some Bagbase wallets, tested one yesterday and the print came out fine but the polyester spine (I pressed it open, not sure if that was right?) went a bit 'melty' has anyone tried these and know what the correct settings are? (I just guessed!) they don't give any info on their website and they are a bit too pricey to keep testing
Thanks!
Quinsfan
Re: Wallets?
Post by Quinsfan »
I press my wallets open but with only the part to be pressed in the press. with the rest hanging outside. Hope that makes sense.
FutureProject
Re: Wallets?
Post by FutureProject »
yup I press one side, then the other so the spine is always just on the outside of the press
Scary
Re: Wallets?
Post by Scary »
thank you, I done another with the edge hanging over as suggested and some paper taped over the spine just in case and it worked perfectly!
