The blanket in my BMS heat press DF1 has started to die, rough guess is about 2000 mugs. It has hot spots on one side.
I'll go with fair wear and tear on that....best replace it then.
This then raises the question of do I order 2?.....I have two DF1 presses and two Adkins presses. As both DF1 presses have done the same sort of volume it might be wise!
I shall ponder over a few coffees.
Janners
BMS DF1 Heat blanket starting to die...so long old friend.
Scotty@BMS
Re: BMS DF1 Heat blanket starting to die...so long old friend.
Scotty.........behave........although it does make the postage less painfull....
You could buy four and hope you get a rush on your mugs!
Scotty, I will collect the commission later
Scotty@BMS
Users browsing this forum: Ahrefs [Bot] and 3 guests
