Mug Press Digital Controllers
rabb
Re: Mug Press Digital Controllers
Post by rabb »
Hi folks,
First post here so be gentle with me :)
Does anyone know where I can buy a new digital control unit for my old generic Chinese mug press? The display has DL8000 on the front panel and the machine model is XY-003.
The timer display works fine and it heats up but the temp display is eratic and goes a bit mental with random characters etc.
Any help would be gratefully received :)
Thanks,
Rab
If you can post a pic of the machine and the timer that might also be useful.
rabb
Post by rabb »
Yea good shout actually :)
vB_ID:3529
vB_ID:3529
vB_ID:3529
vB_ID:3529
vB_ID:3528
vB_ID:3528
There's a company called HeatpressUK who can often track down spare parts for presses. Might be worth giving them a shout :-)
http://heatpressuk.com/
erratic temp display could be a fault with the wiring to the heat sensor, or a problem with the sensor itself. You may be looking at resoldering wires in the plug, or replacing the blanket.
rabb
Post by rabb »
I think it may be the blanket actually as it's not heating up now and the display (when it's not jumping around) is sat at 24 degrees.
rabb
Post by rabb »
Thanks for the responses folks. Really appreciated :)
