Sublimate cycle tops with zips?
logobear
Re: Sublimate cycle tops with zips?
Post by logobear »
We are getting more & more cycle tops to sub, and have historically been nervous around plastic zipps ...... but should i be?
They are MoreMiles tops with the micro plastic zip covered fully by tiny cloth flaps.
Either i have to use my hat press twice to do both sides, - or can I use big heat press and do both in one?
Will the zip melt at 190c ?
:confused:
I sub on 170-180C max. never at 190 so not sure. But on my temperature never had malted zips. Melting point of plastic is much higher then we think.
logobear
Post by logobear »
Top tip Paul, how long at 170-180c ?
60-70 sec. never tried more then 70 max. but i know some people go as long as 90.
mrs maggot
Post by mrs maggot »
if they are a problem get a new rubber base and cut a zip recess in it, just deep enough for the zip, you can then lay the garment across, and sub over the top, - mark used a dremel type tool to sculpt a groove out in mine
logobear
Post by logobear »
Pressing the zipp worked out great, so thanks for the tip.
