Website product design software/modules etc.
Re: Website product design software/modules etc.
I've tried a fresh install but still having issues.
How are you getting on with this? Any chance of a peak/play? i'm at a standstill I'm afraidRavisteam;100842 wrote:Hi Justin ..I am doing my web site using OC 2 (Journal template ) with FPD and so far so good .....Had several bugs in OC2 but I could fix them ....So Justin start again with OC 2 if possible buy Journal Template too(Great template easy to use and mobile friendly )......
Hi Justin Sorry I was away ...My site is not finished by I can see the potential of the these 2 ..Ill send you my link in a while after making it on-line ....Did you try OC 2 with Journal template and FPD..??...I can point you to some of the bugs with OC 2 ( 5 max in the category list and so on ..) ..Justin;100971 wrote:How are you getting on with this? Any chance of a peak/play? i'm at a standstill I'm afraid
I've installed OC2, I avoided it on my last install and stuck to an older version. Trying to use the installer to install FPD but I get an error now.
Yes I had the same ..Contact FPD open a ticket he will fix it for you ..(It might be an OC mode / vQ mode issue )..FPD guys are quick they will fix it for you in max a day ..
Haha, so annoying when I finally get some time to play on a Sunday!
Sameulrodriguez
Using Open-Cart right now but this can all be modified as it's a new website. Techogee is been offering complete customized business websites. Totally responsive business website within 3 days.
And does this Techogee offer the product design software we're discussing here?
Here's a few more to throw into the mix:
http://www.designnbuy.com/all-in-one-de ... html5.html
http://www.developflash.com/LiveArtLite
https://www.productdesignertool.com/cus ... oductId=14
http://inkyrobo.com/jQueryTshirtTool/LivePreview/
http://website.informer.com/visit?domain=fullstyler.com
The key appears to be uploading the image at the start of the design. On OC (at least) FPD only appears to load the full image at the time of adding to cart which is a problem and would cause customers to turn away imo.
