Grainy images
Re: Grainy images
Hi all
I am new to both the forum and to sublimation printing and need a spot of advice.
I am attempting to print black and white photos onto a sublimation mug and the image is coming out grainy. As well as coming out grainy occasionally the black ink looks blue..
I am using a Epson D92 printer.
I have tried various times of transfer from 3 minutes to 4 minutes and it doesn't seem to make any difference. I have also tried putting the mug in tepid water after and again no difference.
I am thinking maybe it is down to the printer and I should buy a better model
Help?
Help?
Re: Grainy images
What profile are you using for the printer?
Also, are you printing on the correct side of the paper and what paper is it?
Re: Grainy images
I am not sure what profile I am using how can I check?
I bought the whole package off a guy on ebay and it came with paper. The paper was in a brown box with no writing on so again not sure what kind it is. I have been searching the web and checked the paper to see if one side was whiter then the other or if one side seemed sticky and both sides seem the same and neither are stickier then the other. I was going to buy some different paper and have a go..
I am using photoshop cs4
Re: Grainy images
Hi Joanne,
You possibly need to download the correct profile. Some of the suppliers might have this or quite often it is available from the Sawgrass website. When you click print and do any settings etc. what program is that in?
The paper used is of a specific type. It is basically a carrier paper that holds the ink on the surface to allow it to be transfered correctly. This usually takes place correctly on one side only. I know some papers you can hardly tell the difference. How does the image look on the paper once printed? Is it grainy then?
Good luck,
Andrew
Good luck,
Andrew
Re: Grainy images
Hi Andrew
When I click print and settings it comes up with Epson stylus D92 series. Is this what you mean?
The image looks a lot paler but doesnt appear grainy although it doesnt look like a sharp print
Re: Grainy images
It sounds like you haven't got the correct driver installed which controls the sublimation ink. Your best bet is probably getting in touch with Martin at Printerowners.co.uk..... he'll probably be along here soon anyway. I don't know if Sawgrass would have this on their site for download as it is an older model. I would also get a pack of paper as the right type can make a big difference.
Re: Grainy images
I use the True pix classic and nothing else although i have tried many others including just normal Epson paper (which my friend swears by) I prefer the Truepix for it's vibrancy. Having said that I have never achieved a decent b+w image, text yes but not a photo. I have a D88.
Re: Grainy images
Sorry there isn't a profile for the Epson D92 as it wasn't a supported printer for sublimation inks.Epson stylus D92 series
