Print n Cut Printer Owners - Bargain to be had.... :-)
Re: Print n Cut Printer Owners - Bargain to be had.... :-)
vB_ID:3403
vB_ID:3403
vB_ID:3403
vB_ID:3403
try these
vB_ID:3404
vB_ID:3404
For some reason it will not let me upload a higher resolution.
Try your end and I will check the details against mine.
ArferMo
Post by ArferMo »
Cant for a bit running of a job of 200 items on another substrate will do when thats done.
ArferMo
Post by ArferMo »
OK... had a call from TMT so tried their suggestions.
Can you try these settings on your Roland and see what Color Chart 1 prints like it could just be the color chart causing the issue.
THT profile in draft mode with Sign & Display:-
These are the ink settings:-
This was the resulting print (even worse):-
