sticker vinyl and application paper
Re: sticker vinyl and application paper
good morning all ,a friend as asked me to make some stickers out of vinyl for him for him to give away as prizes on his website ,now he does not want any patterns just letters ,but what sticky vinyl do i need to produce these ,i should also add that i need it to go through my cameo to cut them out and would i need to add the application paper to the back of it ,thanks very much
i don't want to print them out i just want to use font in the cameo software and cut them on coloured vinyl or carbon fibre type vinyl but what sort of vinyl do i need ,that will peel and stick to different surfaces like if i used hot flex vinyl there is no sticky back , so do i just use sticky back vinyl thanks for the above replies ,
i have seen vinyl stickers that have been bought that come in between two pieces of paper then you rub the vinyl on to the application paper then place it where you want it and peel off the application paper just leaving the vinly decal
you need to get sheets of self adhesive vinyl,
then you cut the font in your vinyl, then you weed away the unwanted parts.
then you place your 4 inch masking tape on top and rub down so the vinyl adheres to the tape
and then peel away gently
thank you very much nash ,could you recommend a good vinyl and where to get it from ,
ArferMo;100286 wrote:Do you have a laser printer or just a sublimation printer.[/QUOTE
i dont want to design or make a decal i just want to use font letters from silhouette software ,so it is just the coloured vinyl i need help with ,thanks arfermo
if you just google self adhesive vinyl and you`ll 100`s of sign writing companies selling off cuts very cheaply
Have a look at MDP, they do a range of vinyl for the cameo (305mm rolls)
http://www.mdpsupplies.co.uk/cameosignvinylrolls.asp
soulclaimed
Arfermo what paper would you recommend for laser vinyl for decals?
