hi guys ive just brought an epsom xp 325 great printer im just having trouble getting the right settings and the print to look right so any help you guys can give would be great
the print seems a little grainy and the colours dont stand out very well
cheers
matt
cant seem to get colours right
Re: cant seem to get colours right
We'll need more info
What paper/ink are you using? What are you pressing on to?
What graphics software are you using, do you have an ICC profile for the inks?
do you print on correct side of paper?
I would pull up a chair make a large cup of coffee and try having a look around this wonderful forum and I am sure you will find many of your questions answered.
I just bought the same printer after having the wf3010D which is an ok printer but started banding and couldn't clean the heads. Anyway I struggled with this 325xp for about 15 mugs well gutted. Finally obviously printed using matt and high as usually and in advanced changed the colour setting from Epson vivid to rgb and at moment seems to ok so give that a try if you haven't already
Yuo don't want Epson Vivid or RBG ... you need an ICC made for your inks used in this model printed, ideally with the type of sublimation transfer paper you're using. If your ink supplier can't supply one, then you'll need to get one made.mugstuff;100020 wrote:Finally obviously printed using matt and high as usually and in advanced changed the colour setting from Epson vivid to rgb and at moment seems to ok so give that a try if you haven't already
