Ceramic Hearts
Help in finding new products.
Tania
Re: Ceramic Hearts
Post by Tania »
I bought 20 Ceramic hearts with a little hole in the top. I have played around with them and they are absolutely gorgeous, I want to produce a couple of hundred but have gone back to order them and they are out of stock, have tried all the other usual suppliers and they are as well. Does anyone have any ideas! Really frustrating!
Re: Ceramic Hearts
We have the ceramic hearts but you'd need to drill a hole in then before/ after printing or consider an alternative way to fix something to the back of the ceramic tile depending on what you wanted to fix it to.
Tania
Re: Ceramic Hearts
Post by Tania »
bms;91991 wrote:We have the ceramic hearts but you'd need to drill a hole in then before/ after printing or consider an alternative way to fix something to the back of the ceramic tile depending on what you wanted to fix it to.
I printed on both sides and want to sell as Christmas decorations. Is drilling a hole realistic? I would worry trying to,stick anything to them for hanging in case they become detached and break.
Re: Ceramic Hearts
Tania;91992 wrote:I printed on both sides and want to sell as Christmas decorations. Is drilling a hole realistic? I would worry trying to,stick anything to them for hanging in case they become detached and break.
Our ceramic heart tiles aren't printable on both sides so presumably not what your looking for.
Tania
Re: Ceramic Hearts
Post by Tania »
bms;91995 wrote:Our ceramic heart tiles aren't printable on both sides so presumably not what your looking for.
Hi, thanks for your help. I have just been looking at your Christmas Ornaments, I would like to order the ornaments in the shape of a diamond but you are also advertising a Taper Ornament but cannot see an image for this, I don't want to order the wrong one and wondered if you would help. Thank you.
mrs maggot
Re: Ceramic Hearts
Post by mrs maggot »
could you use the metal ones instead ?? i have printed them up and they look lovely
Re: Ceramic Hearts
Tania;92040 wrote:Hi, thanks for your help. I have just been looking at your Christmas Ornaments, I would like to order the ornaments in the shape of a diamond but you are also advertising a Taper Ornament but cannot see an image for this, I don't want to order the wrong one and wondered if you would help. Thank you.
The taper image is already online. It's the 3rd image on the right.
http://www.printerowners.co.uk/sublimat ... aments.htm
Tania
Re: Ceramic Hearts
Post by Tania »
bms;92044 wrote:The taper image is already online. It's the 3rd image on the right.
So where is the Christmas Diamond and can you print on both sides. Thanks.
Re: Ceramic Hearts
Tania;92046 wrote:So where is the Christmas Diamond and can you print on both sides. Thanks.
The diamond shape is single sided white metal. Imagine a 10cm square rotated 45 degrees with a hole at the top at the top.
swimwivsquid
Re: Ceramic Hearts
Post by swimwivsquid »
I source mine from Johnsons Plastics in the USA. Very helpful people. However they are porcelain ornaments not ceramic but can definately be printed both sides. Pressure needs to be right though like with tiles to avoid cracking them.Once they are printed they look fab. http://www.johnsonplastics.biz/category/M37/1/1/1185
