Light source argggghhhh!
JMugs
Has thanked: 11 times
Been thanked: 12 times
Re: Light source argggghhhh!
Post by JMugs »
My studio has no natural light, and this can be a problem. I have full spectrum bulbs in the studio, but.... on a certain commercial print I do which is mainly coffee brown it always looks quite green, take it out to daylight and it's the right colour.
The light given off is best described as being like the HID lights of cars, if you look at it you can see it is really white with blue.
So anybody else have this sort of problem with no natural light? How have you overcome it?
Janners
Has thanked: 13 times
Funnily enough in looking at moving into a larger office unit. The one I'll probably go for has a huge skylight but no end window..... The much larger unit I really wanted has no external window which I think it's a deal breaker. Interesting to see how this thread goes forward :-)
JMugs
Post by JMugs »
I can change light sources and completely change the perception of colours, huge skylight is a real gift. No natural light will be a problem.
Post by GoonerGary »
Why do you need to view it in daylight? Abobe RGB colour space or your custom profile and print!
JMugs
Post by JMugs »
The finished article!
Have you ever had a print going to a range of ceramic items where all the ceramics are the same shade of white? I haven't! I have to use different suppliers because one supplier does not supply the whole range, where the coatings are also different, colour profile.....so how do I do that on mugs, steins, vases and bowls... sure would love to.
Yes I do profile but the above items.....please do tell me how...profile on flat items no problems.
Just to round off why do I need daylight....because I like to check my goods are of a high standard.
I shall now get off my soapbox before I get a nosebleed.
Light source?
Janners
JMugs
Post by JMugs »
Hmm just read that and it sounds really grumpy....oh well...now where is my wine...
I prefer to do computer work in a fairly dark room - with consistent light, rather than daylight which is anything but consistent.
In terms of printed works, then yes, daylight is key.
I've not bothered trying to profile a mug, just use white aluminium sheets, but we only use one type of mug which is custom made and bought in from Thailand, so always the same supply thankfully.
JMugs
Post by JMugs »
Hi Pisq totally agree on all points there.
Just one of those things with this client, individual products you would never notice the variations, but next to each other I see the differences.
Janners
I think trying to tweak each image to look the same on different products is almost an impossible task. Trying to find an accurate daylight bulb is probably another impossible task. As mentioned above, daylight changes colour temperature throughout the day, so which one is accurate? Nobody only checks their prints in noon daylight after-all. You could use normal tungsten bulbs and a Wratten lighting gel to correct the colour so that might give you another option if the bulbs are not working out.
We have two Emma Bridgewater biscuit tins in our kitchen with the same design, one is cream and the other closer to white, yeah it bothers me slightly. but I can live with it!
JMugs
Post by JMugs »
Hi Gooner
You are correct, it is the pedant in me that rises to the surface sometimes. A glass of wine followed by a night's sleep has brought back my normal manner.
It is interesting that the full spectrum bulbs cause the greatest problems. My advice to anybody is to avoid them, they are too blue / purple.
I have had a play with the camera as well and the full spectrum bulbs cause all sorts of random colour casts......see I had to investigate!
I do like the full spectrum bulbs for every day working SO LONG as it doesn't involve colour!
Janners
