Help mugs are not looking good
Neilb78
Re: Help mugs are not looking good
Post by Neilb78 »
Hiya
been going great with new kit till now hit my first major problem,
I have a Adkins mug press ricoh 7100 and use corel draw,
Mugs from xpress and tru pix paper, last 6 mugs I have done they look really washed out and faint,
especially the cyan, not at all vivid like when I first started im doing 180 seconds and 180 degrees
Everything im doing is exactly the same so cant understand I did a nozzle check and that looks fine and paper is the
correct way round
any of you seasoned professionals have any ideas
thanks
Has thanked: 11 times
Did you get printer etc. from Xpres? have you asked them to dial in and check settings?
I would also double check the paper, it sounds like either that or a temp/time thing.
What has changed?
You mentioned its been going great and now you have hit a brick wall, so presumably there must be something that has changed...
Neilb78
Post by Neilb78 »
Hiya thanks for your replies, it was in properties it had changed from the profile that the xpres guy
had set up, changed it back and it prints like a dream, thanks
Yay..........
Neilb78
Post by Neilb78 »
Now next question, I have just brought another attachment for the adkins studio press
to do water bottles, how do I change the attatchment on mug press
