Mug full top to bottom wrap
JMugs
Has thanked: 9 times
Re: Mug full top to bottom wrap
Post by JMugs »
I don't normally do a full wrap for the obvious reasons. But a customer wants some...I have held off quoting for the moment.
Question do you trim the image so that there is no paper over the ends, just a few mm over the end or more.
Janners
We print the transfers 5mm taller than the mugs, which gives a good room for error in quickly getting the transfers on. Our designs are quite abstract so the importance is that the image is full bleed top to bottom, rather than straight.
JMugs
Post by JMugs »
Cheers Pisq.
I shall have a play later.
Janners
