Slightly Washed Out Colours on T Shirt (Xpres)
thomasf86
Re: Slightly Washed Out Colours on T Shirt (Xpres)
Post by thomasf86 »
Hey guys.
I'm new here, so please feel free to correct me on anything I'm not doing correctly.
I've got a Chinese Press, Xpres T shirts and an Epson 235 (I know it's a low end printer), cooking at 350F (176 C) for 60 seconds.
The colours are coming out even (what a relief with a Chinese press), but slightly faded, ie not as red as I want, or as red as the printed page.
I've attached a couple of images of a shirt below.
If any of you could give me a little advice, I'd appreciate that! I have a feeling my temp might be too low, but I'd rather get some advice before I start experimenting on pricey blanks!
Thomas
PS It's just a camera phone, apologies for the slightly low quality pictures.
vB_ID:2667
vB_ID:2667
vB_ID:2666
vB_ID:2666
I'd lift the temp. to 190/200c and see if that makes a difference. Could well be the paper or inks you're using though. What paper? I'm guessing inks aren't Sawgrass approved so please don't name them here.
thomasf86
Post by thomasf86 »
I'll be upgrading to an A3 printer in the near future, and when I do I'll be moving to a Sawgrass approved large format ink.
I happen to work for one of the UKs main Ink suppliers as a day job...
thomasf86
Post by thomasf86 »
Also, to further clarify, things are turning out in a satisfactory manner on mugs.
mrs maggot
Post by mrs maggot »
thomas, if you are not happy with that shirt, i suggest you use it to perfect your timing & temp, cut the shirt open, and then you will be able to press a lot more times on it - and you can use the sleeves for future "test runs"
Assuming that the fabric is 100% polyester..
Agree with above points of doing test prints on small sections of the fabric, and trying temps of 200 at 1 minute.
Fabric will print differently to mugs, and maybe you will want to have different bespoke ICC profiles created for the different substrates you will be printing to.
Listawood
Post by Listawood »
Hello Thomas
We always recommend a minimum of 35% polyester for a good result but of course 100% polyester is the best way to go. Start at 200c for 45 seconds and see what the results are like, if it is still a bit faded then try increasing the time in 10 seconds steps
The type of paper you are using can also have an impact on your results. As you are using an Epson printer you could try using a high release paper such as JetCol which is perfect for clothing and textiles. This paper does need some time to dry but will release more ink during the sublimation process which is what these items need.
Best regards
Kris
thomasf86
Post by thomasf86 »
Hi Guys
Thanks for all your advice.
These Ts are 100% poly, really good quality.
I increased the temp to 400F (200C) for 55 seconds and I've got a really really rich, full colour image, I'll update with a picture later today :).
I feel like I've possibly been channelling the dark gods with Dye Sub. With a cheap machine, ink and paper, I've managed to produce absolutely stellar results on my first or second go with almost every blank I've tried. I put it down to studying these forums intensely for a good few months!
Xpres
Post by Xpres »
Couldn't have said it better than Kris @ Listawood. Solid advice there! :smile:
[CENTER]
xpres.co.uk
sales@xpres.co.uk
Stitch Up
Post by Stitch Up »
thomasf86;86947 wrote:Hi Guys
What happened to the pictures?
