Ricoh warranty
petetheprint
Re: Ricoh warranty
Post by petetheprint »
Does using dye sublimation gel invalidate the manufacturers warranty
Re: Ricoh warranty
I'm told by Sawgrass that this is the case yes. Mine went back to Ricoh and I had to keep quiet about its use.
petetheprint
Re: Ricoh warranty
That does not sound good.Lot of money to risk if Ricoh discover its not there ink.
Re: Ricoh warranty
It's the same with every printer manufacturer. As soon as you put in non-genuine ink, and they know this, then they'll invalidate the warranty. I've even had a customer report that Epson invalidate their warranty because they weren't using genuine Epson paper :shock:
