svg to tiff or jpeg conversion
Any OS, software in here.
arthur.daley
Re: svg to tiff or jpeg conversion
Post by arthur.daley »
Hi
I have been sent some .svg files from a client - normally i generate the image that is printed on the mug from jpegs a client sends and text which I generate. However, this one has produced an .svg for me to print. Unfortunately the only computer I have access to at the moment just has Photoshop on it. Can anyone point me to a reliable .svg to tiff or jpeg convertor. I have tried a few thrown up by Google - they didn't work :o( Colours were skewed, entire back ground was turned black, bits of the image were missing. Seems I need something a bit more robust and effective -
recommendations anyone??
regards
Arthur
NikGrey
Post by NikGrey »
Looks like I can open these and save again in the Silhouette Designer Software.
Have not tried this before but if all else fails send me the file and I will see what I can do.
Post by GoonerGary »
Your client has probably used Illustrator or Coral Draw to save the file in svg, ask him to re-save it in a user friendly format. Ideally you want a TIFF. Don't run around trying to convert it, tell him which files you accept.
Svg is vector file format and this is what you really want. Best qualty image instead pixelated raster image.
download inkscape. Its free vector software. You will be able to convert it there.
arthur.daley
GoonerGary;82707 wrote:Your client has probably used Illustrator or Coral Draw to save the file in svg, ask him to re-save it in a user friendly format. Ideally you want a TIFF. Don't run around trying to convert it, tell him which files you accept.
thing is - thats why they come to me, I make it easy for them.
arthur.daley
Paul;82709 wrote:Svg is vector file format and this is what you really want. Best qualty image instead pixelated raster image.
Hi Paul
Inkscape did the trick - once installed it only took literally two minutes to go through the available commands and do the conversion without having to look at the instructions or resorting to foul language ;o)
Thanks for the heads up.
I really can't be doing with having to learn Corel or Illustrator at the moment, even if allows me to put off attending to my tax return :o)
regards
Arthur
arthur.daley;82718 wrote:thing is - thats why they come to me, I make it easy for them.
Most print labs will tell you what they want for good results, they don't want dozens of odd file types being sent to them. The best photographic labs in the country accept TIFF files, so that should be standard enough for us, we are not printing huge bill board advertisements afterall! Inkscape is a handy little program for the odd file conversion.
arthur.daley
GoonerGary;82731 wrote:Most print labs will tell you what they want for good results, they don't want dozens of odd file types being sent to them. The best photographic labs in the country accept TIFF files, so that should be standard enough for us, we are not printing huge bill board advertisements afterall! Inkscape is a handy little program for the odd file conversion.
nothing wrong with TIFF files, nothing too much wrong with jpegs - first generation and not overcompressed. i spent 20+ years as a Senior photographer for Cambridge University. It soon became very apparent that when working on their files it was better to take whatever format they worked with and for me to do the conversion rather than for them to fumble around and attempt to do the conversion themselves giving 'variable' results.
Any lab, pro or otherwise should be able to work with whatever file format you throw at them. However, as that would mean extra work for them which they may or may not be able to charge for, they would always request jpegs and tiffs.
The client who sent the .svg is going to order 20 or 30 mugs, not exactly a big order by the standards of many here, but, if i don't screw up, they will order again next year. They will also pass the on to other associated clubs and positive word of mouth recommendation is the best advertising that money just can't buy.
In short I am picking up the business that other suppliers have lost by offering a flexible and personalised service. This in return generates repeat business and as yet my marketing budget has set me back nothing.
Arthur
That little University clique, I hope you still have a foot still in there.
arthur.daley
GoonerGary;82745 wrote:That little University clique, I hope you still have a foot still in there.
little clique??
12000+ undergraduate students
6300+ post graduate students
and xxxx thousand leave and another xxxx thousand start each year.
quite a large clique I would have said :o)
