Re: Sublimation Dark Transfer Paper
Posted: 18 Jan 2014, 15:30
Hi all ... im interested in the Dark transfer sublimation paper that BMS sell ...
Do you print directly onto the Dark transfer sublimation paper ( not reversed ) and then apply the printed transfer to the t shirt or do you print on standard transfer paper first ( reversed ) and heat press onto the dark transfer paper then cut and apply to garment ...
I have used Xpres Sublitex and the process has to be print on paper first ( reversed ) then heat press onto the sublitex ... then apply ..
Anyone care to explain the exact process here .....
thanks
thanks
