Page 1 of 2
Re: Help Please .. some of the vinyl letters are not 'sticking to the fabric!!
Posted: 11 Jan 2014, 14:07
by PersonalizedGiftz
Works fine when i add the print to a mixed blend socks ( cotton/polyester ) yet sometimes when trying to add the vinyl text to cotton t shirts, vests etc ( 100% cotton items ) some of the letters are not 'sticking' to the garments!! Have tried pressing for longer
tbh im hoping its just that i need to try a different vinyl ... using some of ebay atm hot peel stuff
thanks
Posted: 11 Jan 2014, 14:18
by NASH
Do you pre-press the shirts for 10 seconds prior to applying the vinyl lettering
Posted: 11 Jan 2014, 14:19
yes I pre press
Posted: 11 Jan 2014, 14:22
by NASH
you`ve tried hot peel how about cold peel and also heavier pressure
Posted: 11 Jan 2014, 17:22
by Dave271069
Longer time maybe too,
then try other stuff like MDP, who I find sell a great vinyl, so do xpres and TMT and others.
Posted: 12 Jan 2014, 13:44
by RogerC
Heavier pressure. I had a similar problem initially but once I spoke to my supplier they said 'what you consider to be strong pressure is more than likely medium so raise the pressure and see how it goes'. I did and no more peeling. Job jobbed.
Posted: 12 Jan 2014, 18:30
by Dave271069
i also think we are missing the no 1 lesson here, PRESS AFTER FOR 5-10 SECONDS, once you remove the plastic backing you will need a teflon sheet or maybe greaseproof paper might do, then press,
this should answer your issues.
Posted: 15 Jan 2014, 22:40
I press after too, will give it a try with changing the pressure
Posted: 15 Jan 2014, 23:06
by Renniwano
I know it sounds daft.. but I would be concerned they hadn't sent cold peel by mistake.. maybe check a couple of letters on an old piece of material ??
Posted: 16 Jan 2014, 07:55
by P4UL
Ebay vinyl, ebay heat press? Socks= small print area, t-shirt= large print area. Check your press for cold spots too, maybe you are getting uneven temperature distribution.
