help please
wilky007
Re: help please
Post by wilky007 »
Information on Sublimation Printing needed
Tried to sublimation print on a t-shirt for the first time this evening using sublimation ink and paper, printed onto the t-shirt, printed at 190 for 90 seconds after a few attempts at advised settings, it has printed on the t-shirt but very light print.
Any Ideas??????????
Re: help please
is the t-shirt cotton or polyester
are you sure that the inks are sublimation?
Is your press set for C of F temperatures?
wilky007
Re: help please
Post by wilky007 »
pisquee;81830 wrote:is the t-shirt cotton or polyester
the t shirt is cotton yes it's the same I use for my mugs as for temp I think it is on c as I don't have a manual for it I got it free with a job I did for some one it is cheap one
Re: help please
you can NOT sublimate on pure cotton. you need polyester t-shirt or high polyester content in your cotton :)
wilky007
Re: help please
Post by wilky007 »
Paul;81836 wrote:you can NOT sublimate on pure cotton. you need polyester t-shirt or high polyester content in your cotton :)
would that be the same problem with my mouse mats?
Re: help please
if you have a blank mouse mats from sublimation blanks supplier then no. they are toped with polyester fabric on top and should print with no problem. Why? you have this same problem?
wilky007
Re: help please
Post by wilky007 »
Paul;81839 wrote:if you have a blank mouse mats from sublimation blanks supplier then no. they are toped with polyester fabric on top and should print with no problem. Why? you have this same problem?
yes I am having the same problem with them and I have the same press as you have paul
Re: help please
are you sure you have sublimation inks then?
wilky007
Re: help please
Post by wilky007 »
Paul;81845 wrote:are you sure you have sublimation inks then?
i am not 100% but my mugs are great
Re: help please
so if ink transfer to the mugs then it is sublimation ink. maybe something wrong with your press? how high the temperature clock go???
