Re: Adding Custom Paper Size in PowerDriver.
Posted: 18 Nov 2013, 12:47
by NikGrey
Just setting up my Windows OS again after the Mavericks upgrade disaster (Wiped Windows partition of my Mac).
I want to add my 237x98mm pre-cut Mug Paper paper size in the Power Driver, I keep adding it - says now 'Already in the list' but I can't get it to appear in the drop down list of the Powerdriver. .driving me mad.
Have anyone else had this problem - I had it all as I wanted before :(
Where can I see the list of paper sizes?
Oh, It's windows 7 and the Ricoh 3110dn.
Posted: 18 Nov 2013, 13:25
by NikGrey
So, I can set custom paper size in the Ricoh driver but NOT 'Mirror'.
I can set 'Mirror' in the Power driver but NOT custom paper size :(
Stuck on a small, but important setting again - things like this forever.
This doesn't help.
Done it - what a convoluted way of going about things.
This helped me: Ear.
Posted: 18 Nov 2013, 13:42
by arthur.daley
Hi Nik
After my experience last week at Listawoods I don't think I would entertain using Powerdriver again, it has to be ICC profiles from now on :o)
Arthur
Posted: 18 Nov 2013, 15:04
by NikGrey
Actually, I am trying to get set to do everything in OS X at the moment so I can just use the profiles - the only thing I need Windows for really is the Cutter software (Flexi Starter).
Slightly annoyed today - trying to apply my upgrade key for Silhouette Designer, getting a message that the Key has been used. I used to use Licenturion to protect my software so am assuming their system is the same (keys get used a certain amount of times before somebody there needs to reset them).
Anyway, I have contacted them and waiting for a reply.
Posted: 29 Mar 2016, 11:41
by theTbird
Hi NikGrey
I'm well aware than I'm resurrecting a problem from 2 and a half years ago, but did you ever fix your paper size setting in powerdriver?
I'm having the same issue - it says it's saved it but then it's not in the list!
Em
Posted: 29 Mar 2016, 13:46
by Quinsfan
Nik is no longer on here my friend. He may see this but as a rule he is no longer a poster on the Forum. May I suggest you start a new thread.
Posted: 29 Mar 2016, 16:27
by theTbird
will do, thank you!
