Re: Faded colours on my Photo Mug...using a LC4 Press
Posted: 12 Nov 2013, 18:51
Hi,
I've been trying to find out some clear instuctions on how to use my LC4 Mug Press. I can't find any clear advice on timing and temp. I'm using Ricoh Inks, so I believe that means that I need to have the press a little cooler??
I've put some photo's of my mugs below. As you can see some of the colours are faded. I've also got a slight problem on some of the edges, they are a different colour. And the colour is a bit faded on the red mug, but the one I did before that came out much better (apart from the edges)
If someone could give me some info on time and heat that would be so helpful. My first few came out fine but it's going downhill!!:mad: I am trying to source a manual, but thats not happening either :frown:
Thanks in Advance....
Angie
Angie
