Re: Which Lamp ?
Posted: 09 Oct 2013, 20:29
by NikGrey
Ok, Finally decided which room to dedicate to this Printing /Cutting venture and built a bench system to suit. Just need to get rid of that Glass table and bring my equipment down (from the original 'Small' room).
I will need a good lamp for my 'application table' (As I think I will call it), so I am hoping the clever members here may be able to advise ?
[ATTACH=CONFIG]1991[/ATTACH]
I'm think it will be a fluorescent type deal, it just needs to give a good white light (if that is possible with such old technology).
oh, and I won't be using my super expensive executive leather chair here either - the chair needs to be hard and uncomfortable.
Re: Which Lamp ?
Posted: 09 Oct 2013, 23:27
by NikGrey
No 'Lamp' Experts ?
I'm surprised, but I bet somebody has a preference for what I am after, if not I will just go ahead and over-engineer something to suit my needs
Re: Which Lamp ?
Posted: 09 Oct 2013, 23:50
by socialgiraffe
The best lamps for this sort of work are called daylight lamps which give a more natural tone.
That said I have an angle poise lamp with a flourescent lamp which I purchased from Staples. Very handy and great as it moves around so I can position close up fro intricate work. Its similar to the one below but I know I did not spend £60.00 on it!
http://www.staples.co.uk/furniture-chai ... lamp-black
Re: Which Lamp ?
Posted: 09 Oct 2013, 23:53
by NikGrey
That, young man is exactly the kind of thing I was hoping was suggested - thanks very much indeed
Re: Which Lamp ?
Posted: 10 Oct 2013, 14:18
by RogerC
Daylight bulbs/tubes are essential IMO. With these you get the best lighting conditions, other than actual daylight to check your colours are coming out correctly. Other light sources (electric) will give a colour cast...as I found out to my cost with banner printing. I scrapped one because the colour was wrong then took the next one outdoors to show she who must be obeyed and voila the colours were as they should be hence I now have daylight tubes.
Re: Which Lamp ?
Posted: 10 Oct 2013, 23:32
by NikGrey
I wish there was a 'Like' button on this forum (So everybody knew when a reply had been seen at least).
Thanks for the replies - on Thursdays I present a Hospital Radio Request show, only just got home.
Will catch up in the morning but I do think 'Daylight' seems the way to go - I popped into Hobby Craft earlier as I was nearby and they want something like £120 for such a lamp.. as soon as I settle on what I need I will find it for an agreeable price
Re: Which Lamp ?
Posted: 10 Oct 2013, 23:39
by socialgiraffe
You do not need a special lamp for a daylight luminaire. An example below is one I just did a quick search for on the web
http://www.homecrafts.co.uk/buy-dayligh ... tAodqQQAMA
P.S. You should not call them bulbs (although everyone does). I once did a presentation at Philips lighting for a marketing strategy and the first time I said bulb someone shouted "they are lamps, bulbs are sold in (insert rude word here) garden centres"
Re: Which Lamp ?
Posted: 11 Oct 2013, 11:15
by RogerC
I'll second what SG said.....the things that 'light up'..call them what you will...bulbs/lamps/tubes are available in 'daylight temperatures'. You don't need a specific 'expensive rip off' complete light/lamp to do the job. These light sources are available as 'bulbs' and tubes for fluorescent units so don't go paying a fortune for something that can be sorted for a few £'s
Re: Which Lamp ?
Posted: 12 Oct 2013, 22:45
by NikGrey
Apologies for using the 'B' word in the context of Lamps.
I bought this one:
Ere (Not from this company at that price) - I found one for £45 which is much more acceptable.
Bit the bullet today after spending an hour or so Weeding with only the main room 'Lamp' on - that was not the most comfortable experience.
Will let you know how it performs.
Re: Which Lamp ?
Posted: 13 Oct 2013, 23:14
by mrs maggot
the take a break section always used to have jokes n stuff in it, makes a change for it to have other stuff in it
