Page 1 of 3
Re: Which ADKINS heat press to choose ?
Posted: 06 Oct 2013, 21:21
by miniumini
Hi all.
I'm new on this forum so please be patient :tongue:
After long research I decided to buy ADKINS heat press from XPRES for t-shirts and I don't know which one of these two choose:
1. XP7051 Studio Auto Clam Junior Press 40cm x 40cm
http://www.xpres.co.uk/p-8246-studio-au ... -40cm.aspx
or
2. XP7053 Studio Auto EZ Clam Press 40cm x 50cm
http://www.xpres.co.uk/p-8248-studio-au ... -40cm.aspx
Both seem to be well built. I like the heating plate mount in XP7053 (Auto EZ one) but don't know why case has many holes ?
The XP7051 looks even better but is a bit smaller and a bit more expensive.
Could You help me choose better one please ?
I'm also considering STAHL Hotronix MAXX 38cm x 38cm.
Any sugestions ?
Regards.
Posted: 06 Oct 2013, 21:27
by Jason
Adkins are pretty much the industry standard press in the UK, personally I would go with an Atkins swing-away, this is because Clam presses struggle to exert the pressure required for some of the laser papers available.
Posted: 06 Oct 2013, 21:42
by miniumini
Thanks for quick reply.
I was thinking about swing-away but I don't have enough space for it. That Auto EZ has 4 springs which I think helps evenly distribute the pressure at each corner. But these holes looks weird to me :tongue:
I will print on RICOH ink printer. Will use flex/flock too.
I have to choose one from these 3 above I'm afraid.
Posted: 06 Oct 2013, 21:47
by Jason
Hi,
All are very good presses, from these 3 I would go for the one with largest platen size.
Posted: 07 Oct 2013, 10:09
by thecartoonman
Hi
Find the space! The swing away will last you for year's, we have had one 10+ still going strong and it gives you the flexibility to print everything.
Posted: 07 Oct 2013, 10:20
by socialgiraffe
I agree with this, I had a cheap clam shell one which although very good was not up to pressing everything I needed it to. So I purchased a swing away from The Magic Touch and just made sure I had the room for it. Superb machine
Posted: 07 Oct 2013, 13:04
by miniumini
That's what I just did. The swing-away is on the way now ;)
Thanks lads for your help.
Regards
Posted: 07 Oct 2013, 15:22
by thecartoonman
Well done, you will not regret it. These Adkins presses are at the top end of the price scale for a reason, they are 1st class, never let you down and there is a full UK spares back-up to replace the items that do wear with lots of use. Happy printing.
Posted: 07 Oct 2013, 15:57
by miniumini
Thanks again ;)
Posted: 02 Nov 2013, 14:14
by beco1979
Which one did you buy in the end and how is it working out?
