Latte mug press problem
Re: Latte mug press problem
I am trying to use my mug press purchased from coralgraph, but when I put the 12 oz latte mug in it falls out. Has anyone pressed latte mugs and have any advice on how to use them? Also, if I give up on trying this press does anyone know where to purchase the blankets so I can use in the oven?
PICS-ON-GIFTS
The Transfer Press have blankets for most things. Or I think Listawood Trade Supplies have, too. Check them out!
Janet
Janet
Have you got the right blanket in it? Have you tightened it up correctly. I have one from Coralgraph and mine has never fallen out!
Not a good idea unless you are absolutely certain that the blankets are wired the same. Most of them are, but if you are not an electrician it would be advisable to get someone who knows what they are doing to check first.The Transfer Press have blankets for most things. Or I think Listawood Trade Supplies have, too. Check them out!
