Sublimation sticker sheet
confidential
Re: Sublimation sticker sheet
Post by confidential »
Hi all,
I'm looking for some sublimation sticker sheet to create some graphics for my motocross bike.
http://www.printerowners.co.uk/sublimat ... ticker.htm
Martin.
Would this be suitable, bearing in mind it will need to stick into recesses and around curves etc? Is the silver finish reflective or more of a sheen?
Cheers
Would certainly stick around curves. Not sure about the recesses as it depends on how recessed these are. If normal sticky vinyl would stick then the sublimation sticker should be okay. The silver isn't a pure mirror but it isn't totally matte sheen. I'd say it is more mirror like, than matte sheen.
confidential
Thanks Martin, I will order an A4 sheet of each for a dummy run.
