Re: Coral 4 mug press settings?
Posted: 08 Aug 2013, 19:16
by Tryweryn
If anyone is using this machine can I ask what settings you use, time and heat? Many thanks.
Posted: 10 Aug 2013, 16:31
by viccar
I use this, with ricoh printer i use 170 and 170 seconds varies a bit if using different mugs. but its a good starting point.
Turn it on (top switch on, bottom switch off) put a spare mug in the blanket, set the temp, and time then when it beeps, put your mug to be printed in and turn the bottom switch (timer) on wait for it to beep, take mug out. turn bottom swithch off.
Posted: 10 Aug 2013, 19:14
by Tryweryn
Thanks soooo much I got it down to a T now....after wasting about 8 mugs lol
Posted: 22 Aug 2013, 00:25
by Tryweryn
Actually I now use 180 for 170 seconds. I changed to BMS mugs and every mugs a perfection lol
