Page 1 of 2
Re: Mug transfer stain/mark issue
Posted: 29 Jul 2013, 00:18
by jay
Hi all I keep getting this green mark at the bottom off the mug from time to time(see pic below). Im not sure how its happening as it seems to fit into the mug press perfectly and transfer paper fitting snugly around the mug. Has anyone ever had this or advise on how to avoid it? it happening far to often for comfort. thanks in advance! [ATTACH=CONFIG]1880[/ATTACH]
Posted: 29 Jul 2013, 06:10
It looks from the picture life the print isn't transferring properly onto the mug. Try pre- heating the base for 20 seconds before pressing.
Posted: 29 Jul 2013, 08:09
by Paul
Yep. I think this is as justb said, not even surface or something? Is this 11oz mug ?
Posted: 29 Jul 2013, 08:32
by jay
Yes it's an 11oz. What's the best way to pre heat? Thanks for the help!
Posted: 29 Jul 2013, 09:48
You can put the lowest inch of the mug into your press for 20/30 secs, that's my preferred method. You can also get a small heated tray and sit mugs on there to preheat a little if you're doing a few. Some folk even put boiling water in the bottom of the mug. Your aim is just to give that lower section a head start by getting some heat into the thicker area.
Posted: 29 Jul 2013, 10:05
by Paul
Or...
this could be that heat don't go to that place at all as mug is uneven. Are they ebay mugs? I found them very uneven and hard to work with.
Posted: 29 Jul 2013, 10:06
A trick I've seen for uneven mugs but never used personally is to dampen the transfer at that point so it sticks to the mug prior to pressing.
Posted: 29 Jul 2013, 10:15
by tlworkwear
Haven't had this happen to me yet but a good thing to bear in mind so thanks for the tips :)
Posted: 29 Jul 2013, 10:31
by Andrew
If it just happens now and then I would say it is the mug being mis-shapen at the base where the print is faulty. A bigger taper than normal. You would need extra pressure on your press to try and take up this flaw so that the element gets direct firm contact with that area which is currently not happening.
Posted: 29 Jul 2013, 11:04
You could also try pressing upside down if your press will allow :-)
