Re: Ink Jet for Dark Garments frm Yolo dont stick firmly
Posted: 20 May 2013, 11:23
by Ravisteam
Ive done some transfers using Yolo Jet Opaque II on some of Dark cotton T-shirts .All the time the edgers seems to be not stuck to the t-shirt properly ..!!!
It seems like you peel it off by the edges but rest of the transfer is firm and wont come off easily..I am I doing it wrong ???> .Please help me how can do it correctly ???>
Posted: 20 May 2013, 11:40
by NASH
i normally pre-press the garment to remove moisture then press with firm pressure, remove silicon paper then stretch the garment both ways diagonally and horizontally and press again for 5 seconds. Never had any problems doing it this way
Posted: 20 May 2013, 12:12
by Ravisteam
Thanks for your quick reply Nash ..Ill try it today and post the results ...Cheers
Posted: 20 May 2013, 12:14
by Paul
I do same as nash. But i always wait few seconds before i peel the silicon paper.
Posted: 28 May 2013, 23:43
by soulclaimed
i had the same issue with the dark transfers from xpres theyre awful to use, when you peel it off the backing sheet the edges roll up so if youre doing a photo print you have no chance of straight edges and they dont stick down, 3g jet opaque is good though but its a bit plasticy on the shirt...
Posted: 29 May 2013, 10:54
by NASH
i lay my transfer on a A3 hardboard away from the press with a silicon sheet on top and stick down with heat tape on all four sides and then take the board to the heat press and the gently slide the board away and then press
Posted: 30 May 2013, 00:34
by mrs maggot
soulclaimed, use the vinyl backing sheet from some sticky vinyl and simply stick to it BEFORE you peel the backing off, or use some of the vinyl carrier sheet that is sold, i save my sticky vinyl backing for using for this - works a treat
Posted: 30 May 2013, 21:58
by soulclaimed
mrs maggot you are everywhere lol and as always super helpful :)
