Silhouette Cameo Illustrator Plugin not working
tlworkwear
Re: Silhouette Cameo Illustrator Plugin not working
Post by tlworkwear »
Hi all,
Ive just got a Silhouette Cameo cutter after owning a Craft Robo for the past couple of years. It works a treat in Silhouette Studio but I have hit a snag with trying to cut in Illustrator. I know there is a plugin called Cutwizard so thought I would download the 14 day trial to see if it would work but it doesnt come up as an option like Cutting Master 2 did for my Craft Robo. When I read the manual it said that once installed just go to file then the option would be there but unfortunately its nowhere to be found :/
Im running Windows 7 with Illustrator CS5 in case anyone needs to know. Many thanks in advance for any replies or ideas.
Phil
viccar
Post by viccar »
Is it the full version of illistrator? not the home and student version.
tlworkwear
Hi, thanks for the reply. Its the full version as far as I am aware. Is there any way to check?
