wooden cross
Re: wooden cross
Does anyone have a template for the wooden crosses. They have a ovel coaster style that you print on that fits in the cross. Are they the same temp and press times we use for coaster. Found some in a cupboard and thought I would use them, won't earn money in a cupboard
Re: wooden cross
Are these the UniSub crosses? There may be a template available if they are. As for temp and dwell times, if they are the same material as the coasters then the temp is 190-200 degrees C for 50 - 60 seconds. If they've been in a damp place for a while (not suggesting your cupboard is damp!) then press them upside down for 30 seconds to get rid of the moisture.
Re: wooden cross
Yes they are UniSub, never thought about the damp, but no our house is cold so cold but not damp but if you have a template I would be so greatful
Re: wooden cross
http://www.unisub.com/templates/templates_main.html
http://www.conde.com/templates.php
Possibly something on one of these sites?
Re: wooden cross
I use photo shop and had a look at all of them but would not transfer to a template any ideas, thanks for all the adive.
Re: wooden cross
It was the right cross but the whole thing down loaded coaster, cross and all. I neeed the outline for the coaster bit. Can you help.
Re: wooden cross
I can't open this as its in croal draw, I just need the coaster template that fits in to the cross
Users browsing this forum: Semrush [Bot] and 3 guests
