Page 1 of 2
Re: Do I need teflon sheets?
Posted: 04 May 2010, 21:28
by Louise
SO the new press arrives on Thursday now, but just before I buy teflon sheets for it, do I need them?
I have read that you can use greaseproof paper or silicon paper, presume the stuff you can get in supermarkets?
Any recommendations on what to use guys?
Thanks in advance. 8-)
Posted: 05 May 2010, 17:08
by AJLA
I have belt and braces although not always used together, I do use greaseproof every time I print a sbuli t shirt to prevent the ink from transfering through as sometimes it could go onto your press, then onto the next t you print, or mug in your press, I usually use the teflon sheets when pressing vinyl.
Posted: 05 May 2010, 17:20
by Kaz
I had that happen on the first run of tees I made :roll:
Posted: 05 May 2010, 17:25
by AJLA
ME TOO :oops:
Posted: 05 May 2010, 17:59
500 A3 sheets for £30 from Xpres, last ages and can save a blooming nightmare with the image transferring :x
Posted: 05 May 2010, 18:13
by Louise
Thanks for that, Ive just noticed I get 2 teflons with the press but I think I'll get some of the normal paper too. Thank you for sharing your slip ups too, guess Ive got a lot of those to come! reminds me of the early days embroidering, had some great mess ups then :lol:
Posted: 05 May 2010, 22:06
Edit my last post, £25+vat for 500 silicon sheets from Xpres.
Posted: 06 May 2010, 12:23
by JSR
When I first got my flatbed, I bought two thick teflon sheets (from Revolution). I wrapped one around the base of the press (secured in place so it doesn't ever move).
I then use a belt & braces approach. I use rolls of greaseproof paper from Tesco. One lays over the base (over the teflon), then the item with the transfer over it, then a layer of greaseproof over the transfer paper, and the second Teflon to protect the top of the press (the heat platen).
It sounds like overkill but I once tried to do a bag and the straps melted. Had it stuck to either the rubber base of the press or the heat platen, it would have been a real job to clean off. But as it only came into contact with the teflon, it took just seconds to clean off.
The Teflon sheets are the same ones I bought years ago, but I use the greaseproof as a cheap "single use" protection. The press, underneath the teflon sheet, still looks as good as new.
Heat presses cost a lot of money to replace, so it's not worth scrimping on a few pennies to give it added protection from accidents.
Posted: 07 May 2010, 20:48
by Louise
Thanks for the replies.
Well I got 2 teflon sheets with the press for free so thats good, also ordered some of the silicon sheets too and have a roll of greaseproof on hand, so I think we are all set for the first try!
Mind you, how big are those presses when they arrive :shock: It didnt look that big at the show room :lol: But in the office! Still I hope it will good, we went with an Adkins swing press, hoping that was a good choice, time will tell I guess.
Posted: 08 Jun 2010, 08:18
by sunny09
hi , if the heating plate have teflon coating, so you dont need the teflon sheets,otherwise you need.
