GOLDCUT JK Series
Dave271069
Re: GOLDCUT JK Series
Post by Dave271069 »
Right im having a little difficulty in setting this up on my pc, GOLDCUT JK Series driver will not go onto windows 8 has anyone else put a Chinese cutter like this onto a new pc with 8 on it? it wont let me install the driver, i will go and get my laptop out of caravan in a min and try it on windows 7, im using instructions from lovecut refine cutters
Dave
Dave271069
Can you tell me if you look in your printer selection on pc will a chinese plotter be here as a installed printer?
Has thanked: 13 times
Been thanked: 12 times
Only if you've installed it as a printer, otherwise no.
Dave271069
ok, ive been on this for 3 hours solid, im using cheap cheap and cheap but i will concur it, bought a Refine 870, all working order but no software, im using signblazer at the moment until new stuff arrives, god is hard work lol
Dave271069
In my control panel under devices and printers my cutter appears as UNSPECIFIED and USB-SERIAL CH340 (COM4)
can anyone tell me if this means my pc has recognised my vinyl cutter and is ready for software.?
yes it is. jus in software setup make sure your cutter is set for com4.
Dave271069
Thanks Paul,
im getting there slowly, signblazer is playing up now, but before i try and cut something does anyone know what lights should be on or off on the cutter?[ATTACH=CONFIG]1746[/ATTACH]
image is poor red light is RESET under neath is ONLINE/OFFLINE under that is SETUP
Arbydoo
Post by Arbydoo »
Hi, We have moved to France from the UK and have been trying to reset up our KH-720 cutter. I have unfortunately lost disk 1 but still have disk 2 with Artcut on it.
Can anyone advise where I might be able to get the drivers for my cutter.
Many thanks in advance
Arby
Is it just the USB driver? I have one for an old cutter here but it was a 721 model, wonder if it might work?
